westend
Aug 18, 2015Explorer
Chris Bryant wrote:MEXICOWANDERER wrote:
OK
I can make out 330uf on the caps but cannot see the voltage value. Eyes are simply too weak because there is not a lot of room in there. Any ideas? Thanks.
If you are talking about the largest capacitors, on the 3 55 amp wfco's I have here they are 820 uf, 200 volt, 105c .
Westend- thanks for the dim bulb tester- I'm figuring out whether to sell the thing as is or put the money in to restoring it, but selling as is would like to have it working. FWIW, it's a McIntosh C22 I bought in 1975.
Yeah, I was going to suggest anything above 200V. There should be no issues with inrush in the values and locations mentioned.
Your McIntosh is a well regarded unit. If you plan to keep it, send me a PM for recommended service folks in your region. If you plan to sell it, bring it up on the dim bulb tester and sell as/is would be my suggestion. For most buyers, the condition of the faceplate is more important than the function of the electronics.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 27, 2026
