BFL13
Jun 08, 2018Explorer II
valhalla360 wrote:
It will be borderline.
60amp at 12v is 780w but when you account for losses or variations in voltage as the system isn't 100% efficient at converting AC to DC, you need to feed it more than 780w.
The 1000w Honda is only rated at 900w continuous duty. That leaves you only 120w to cover losses. This also assumes you have isolated the AC circuit feeding the charger. Doesn't take much to eat up 120w.
If you dropped back to around a 50amp charger, I would say it's a safe bet that it will work.
Since you are on the edge, you may run into issues where one day it works and another it doesn't...if you are at higher altitude or it's very hot, the power output will vary a bit.
Another one that doesn't know about VA. :(
BTW, efficiency ratings for these things are in watts, not VA, which can be misleading. If there is a PF, that makes it worse than it looks using just watts. Typical advertised efficiency for converters is around 85%. In the above example with the 55a converter:
Watts out-- 56.8a x 14.8v (set) = 841w
Watts in--- 980w, so efficiency is 841/980 = 86% BUT,
If you use the actual input required in VA, it's 841/1383 = 61%
Which is why they advertise the efficiencies using the watts. It also shows how PF can get mixed up with "efficiency" when looking at all this.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
