MEXICOWANDERER
Jul 24, 2017Explorer
"Oooooo look for the little circuit breaker - it probably failed"
How many dozens of times have I read that on this forum...?
If you think those little breakers are the Cat's A--, well they will act exactly the same as a large circuit breaker. Proportionate heating, thermal de-rate curve, the whole ball of wax.
When a fuse is exchanged for a circuit breaker, precise protection measurement is forfeited for convenience. Don't give a **** if it's a $2.99 parts store breaker or a twenty dollar ganged Square D breaker, they are thermal animals and "precision" isn't spoken.
Larger breakers are ideal in dedicated power transmission circuits. Chassis bank feeding hotel bank and vice versa. Armageddon short. A six gauge intertie cable that passes say forty to fifty amps but protected against 100+ amps shorts. Well within the ampacity of the cable.
There are specific fuses for protecting electronic circuits and they sure are NOT ATO plastic case or SFE 14 type. They are instant reaction of precision accuracy.
Getting the drift?
Stick the linked 100-amp breaker STYLE against a standard breaker - call it fifty amperes ratings for both. Think the parts store 50 amp breaker like shown in the image above, will "outperform" the 50 amp lever breaker? Think again. The lever breaker is far more reliable.
Quicksilver's extremely expensive Klixxon switch breakers are backed up with cartridge fuses at individual point of loads. When the water pump took and end-of life dive several years ago it was not the 20 amp dedicated breaker that tripped - it was the 20-amp cartridge fuse at the pump. It worked as per design specification.
Circuit breakers and dedicated fuses - two devices for two entirely different purposes. A wiring fault can be determined in two ways. Recycle the the breaker or have a load of cartridge fuses "just in case".
I'll run one of these cheapo breakers in competition against a forty dollar Klixxon breaker and furnish the results...
Getting the drift?
