westend
Jul 03, 2016Explorer
2oldman wrote:An owner can get around paying retail cost of mounting brackets by buying lengths of aluminum angle and cutting to desired length. Holes will be needed so a drill is required.Gonzo42 wrote:Another surprise cost is the mounting hardware, if you should you want 4-corner roof mounting with tilting.
That might just make me go for it. Wonder how much the controller and other required items cost?
Some folks are capable of DIY stuff, but not me.
FWIW, I built a 4-way tilt mechanism with struts and two hinges for less than $50. This mechanism is more than anyone truly needs. Eight angle pieces with fasteners and struts for tilting should be less than $30.
