blueh20
Oct 21, 2018Explorer
10ga or 12ga help wanted
I am mounting a new flojet water pump on my 2014 ford e250 conversion, the pump says 7.5 amps at 50psi.
The instructions that came with the flojet says to run 12ga up to 50ft.
I have a 23' run, thats from the battery thru the fuse block to the switch then to the pump.
running 8ga from battery to fuse block which is 5' away, running a 30amp breaker on the fuse bloc.
I was planning on running a 10ga loop which equals 46', the 3 elec. male slide on connectors built into the switch are to small to attach 10-12 ga female connectors to, they wiggle when attached and are too narrow for a good fit.
The other option is to just run the 12ga for the 23' and ground the pump to the vehicle right next to the pump..
All my other wiring in the conversion I have done as a loop back to the fuse block.
Blue Sea systems chart says 8ga for a loop. Most charts say 10ga for a loop and found one that says 12ga loop.
Looking for input and comments from experience..
thanks
thanks
