dryfly's avatar
dryfly
10K psi grease gun
I'm having issues getting grease into the some of wet bolts of my trailer. I've tried the usual remedy of lifting the trailer to decrease weight off the axles with no results.
Before I try to remove the wet bolt for inspection/orientation I'd like to try a 10,000 psi grease gun and possibly a Lock N' Lube coupler. Can anyone suggest a quality grease gun?
  • If you jacked right next to the spring hanger you are trying to grease and it didn't work, it is time to pull the bolt and see what is going on. That higher pressure gun will do little to help you. If you do the math, that tiny hole will deliver a psi number much smaller than you imagine.
    I have suggested several times on here to cut a figure 8 inside the bushing to give the grease a path. Only feedback I got was criticism.
  • Is this a new wet bolt kit or is it old? If it is old with old grease you might want to try a propane torch to heat the grease in the wet bolts.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
