MrWizard
Nov 01, 2014Moderator
you say your running off the inverter
built in inverter, powering the SAME outlets ? and the work from inverter ?
could be the transfer switch inside the inverter..
you didn't happen to plug an electric heater into one of those outlets did you ?
what is charging the batteries ? power from inverter won't last long if your dragging down the batteries
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
