docj
Nov 01, 2014Explorer
BillandCarole wrote:
Were running off the inverter and the 12 volt system. My voltage tester shows power going to the GFI.
Does your inverter have one or more circuit breakers following it on a subpanel or built into the inverter itself? Our Xantrex had two little breakers on the front panel which often tripped and caused a situation like you describe. I know you said that power is going to the GFI, but you might want to double check. Is there only one GFI feeding your entire RV? That's a little hard to believe; I have at least four that I can think of.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
