CA_Traveler
Apr 26, 2016Explorer III
ivbinconned wrote:Yes you are wrong to assume. Simply trip the breaker and see what doesn't work which will also verify any markings.
Thanks for all your input here folks. Just one more question. Am I wrong to assume that if some plugs are fed from one side of the power supply and others from the other you could actually have two 1500 watt electric heaters going? And or is there a chance that the electric fire place is fed from one side and all the 110 plugs from the other?
All plugs, fireplace and more can be on one leg since it's 50A. Your limit would the gen if less than 12KW.
I can run 3 heat pumps plus 3 ceramic heaters plus whatever else is on.
