MEXICOWANDERER's avatar
Aug 09, 2014
12.00 Volts to 10.00 Volts LED Bucker
Never a dull moment. Genuine 10 watt LED chips (they need a heatsink) are not 12.00 volts capable.
Driven much higher than 10.00 volts, light output stays the same but heat increases as dramatically as lifespan decreases dramatically.
A realistic 2 volt drop (higher when batteries are being charged) is available by using series diodes.
A quandary. Christmas tree light string diodes or a DC to DC buck converter which is also a regulator.
But how nicely do DC to DC converters play at a 2.0 volt Delta T ??
Chinese manufacturers seem to be rather unclear on the subject.
"Work fine 12 volts 24 volts" But when I redirect specifically to the 12.00 volts to 10.00 volts question, it's either "So sorry don't know" or no response.
This question is not academic. "Properly" driven an LED can emit 95% of the light of a max driven chip but develop 80% of the heat. Heat means heat sink, and large heat sinks double or treble the price of a chip assembly.
Heat sinks are priced like diamonds. Go a little larger and WooWee.
Thanks for the input
EDIT
By the way, the light temperature of the 5K 10 watt chips is as close to sunlight as I have ever seen in an LED emitter. No pink or blue or yellow.
  • HOw many LEDs are you running in series?
    I've been using this one for a month continuously and it can hold, at a fan rated at 1.3 amps, 1.2 volts below input voltage, and the output voltage stays steady no matter load or input voltage.
    http://www.amazon.com/DROK-Adjustable-Regulator-Experimental-Converter/dp/B00BYTEHQO/ref=sr_1_1?ie=UTF8&qid=1407222286&sr=8-1&keywords=DC-DC+Voltage+Regulator
    They have less expensive versions without the voltmeter display.
  • Here are the chip OEM specs. I am attempting to keep finished price under control. I am dealing with multiple dozens of chips and heatsinks. Some are individual lights, others are small clusters to (4) units.
    Color: Cold white
    Forward Voltage (VF): DC 9-12V
    Forward current (IF): 1050MA
    Out put Lumens: 800-900LM
    Color temperature: 6000-6500K
    Beam Angel: 140 degrees
    Life span: >50,000 hours
    Size:
    Lens Color:Water clear
    Viewing Angle:120°
  • If your LED (array) is bare, that is, no other electronics involved, then you can put voltage aside and only worry about current, since LEDs are current mode devices.
    On china-e-bay, there are plenty of adjustable constant-current LED drivers. If your delta-v is very small, a SEPIC type driver might be the best fit, as it allows input voltage to be higher or lower than output voltage.
    350mA SEPIC driver
    700mA SEPIC driver
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
