On first trip of the year old house battery (group 27) died 6 hours after setting up. All the 110 appliances worked, but all of the 12-V lights dimmed; battery indicator on the house monitor said it w...
To drain a fully charged battery in under 10 hours indicates there is a pretty good drain on the battery, but not enough, or in the wrong place, to blow a fuse.
Could a wire have been damaged in your collision last year?
I don't suppose you have a clamp-on ammeter to measure the current drain, or a charger to recharge the battery. About all you can do, for now, is look at the battery wiring to see if you can see any damaged or shorted wires.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
