On first trip of the year old house battery (group 27) died 6 hours after setting up. All the 110 appliances worked, but all of the 12-V lights dimmed; battery indicator on the house monitor said it w...
Check that your converter AC circuit breaker is on. If yes, is it putting out around 13.x v at the terminals in the back of the unit? If yes your problem is probably a broken connection between the converter output and the battery.
Meanwhile a portable battery charger hooked to the battery would probably get you through your holiday weekend.
Jim
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
