Tom_M1
Jan 17, 2020Explorer
MrWizard wrote:This is a buck converter. What is needed is a boost converter. A typical buck or boost converter needs a two volt differential, meaning for 12 volts in a buck converter will have a maximum output of 10 volts. For boost the minimum output will be 14 volts. Or you could get a buck/boost converter which will function as either with no voltage differential.
Drok dc to dc converter
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
