No power in the cig lighter socket at the dinette table, no porch light, no stairwell light, and the aux battery switch no longer has loud switching noise. Checked all circuit breakers and fuses tw...
Please explain what you are calling the Aux Battery Switch. Circuit breakers are 120 volts so forget about them. The only breaker that has anything to do with the 12 volt system is for the converter. It charges the battery and supplies 12 volts for the 12 volt system When plugged into shore power,
Be sure your telling us ALL the things that don't work. What you describe sounds like it is just one fuse blown. Explain how you checked the fuses.
