Gonzo42ExplorerJun 16, 201912 VDC lossNo power in the cig lighter socket at the dinette table, no porch light, no stairwell light, and the aux battery switch no longer has loud switching noise. Checked all circuit breakers and fuses tw...Show More
Sam_SpadeExplorerJun 17, 2019You NEED a multi-meter to check voltages.Without that, you need to find an RV shop to check it out.Dead battery.Loose battery connection.Failed "aux battery" solenoid (fairly common).But you should NOT be doing ANYTHING based only on a guess.Some testing is necessary.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related Content12 vdc fridge12 volt only refrigeratorReducing 12 VDC to 9 VDC12 Volt Power IssueNo 12 VDC Cabin Power
