RJsfishin
Feb 14, 2015Explorer
If I was forced to connect any white wires at the battery, I wouldn't get anywhere the positive terminal !!
And if for some stupid reason someone really did use white for positive, I still would not connect them until they one way or tother change color to red or black !
BurbMan wrote:
They may be wires coming from the converter that charge the battery when plugged in. Typically the ground is run through the frame (like a car) so chances are those are both (+). If you have a multimeter, set it to ohms and see if you get any continuity between either of those wires and the frame, just to rule out them being grounds. You may want to crawl around a little and see what you can find out before connecting them. Or maybe call the guy you bought it from and ask him?
Oldman....ya gotta lay off the hooch this early...what "hotties below the picture?"
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
