wa8yxm
Dec 02, 2014Explorer III
Filament in a CFL? I too have never seen a 12 volt CFL, though I have seen 12 volt Edison Based lamps they were incandescent. (in fact I have one or two in stock)
I would go with LED One LED item I have found is from Radio Shack 21.95 for a meter of LED's and you can cut it into 5cM strips, there is a 5cM test strip on the package with batteries, you can see how bright it is. Do not yet know how well it will work.. Waiting for a pair of tubes to fail before I install, but sure looks promising.
http://www.radioshack.com/radioshack-led-waterproof-flexi-strip-60-led-1m-white/2760329.html
Also comes in red and tri-color but you want white.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
