CSCustomCars's avatar
CSCustomCars
12 Volt Computer Fans not working (long-ish post) SOLVED
Hello everyone,
I'm trying to install some computer case fans in my roof vent that has no fan in it above the kitchen stove (who's idea was that?).
The problem I'm having is they will not work when connected to power in my trailer.
Let me add, I am an auto mechanic, have the knowledge and skill to diag for the most part, but am at a loss here because it doesn't make any sense.
I bought two of these fans:
THERMALTAKE RIING 12 SERIES
Specs:
P/N CL-F038-PL12BU-A
Fan Dimension 120 x 120 x 25 mm
Started Voltage 9.0 V
Rated Voltage 12.0 V
Rated Current 0.2 A
Power Input 2.4 W
Fan Speed 1500 R.P.M
1000 R.P.M (with LNC)
Max. Air Pressure 2.01 mm-H2O
Max. Air Flow 40.6 CFM
Noise 24.6 dB-A
18.7 dB-A (with LNC)
Bearing Type Hydraulic Bearing
Life Expectation 40,000 hrs,25?
Connector 3 PIN + LNC (Low-Noise Cable)
Weight 158.8 g
Yes, this is a 3 pin fan, however, the third wire is just a hall effect sensor to tell the CPU how fast it is spinning.
With each fan mounted, I tested each with a 9v battery. Both started working. I then wired a cheap switch to both fans on the ground side, connected both fans together, wired the ground through the switch, then connected again to a 9v battery, flipped the switch fans turn on, flip the switch fans turn off.
I tap into power at the bathroom fan. I get power from before the bathroom fan, and ground after the switch for the fan. Connect up the fans in the kitchen, and nothing. I reconnect to a light on the ceiling, nothing. Disconnect, check again with a 9v battery, still works with a 9v. Bathroom fan still works fine.
What on earth is going on here? Do I need a voltage regulator before the CPU fans? MOST CPU fans will operate over 12v, even up to 20 volts. They have very little draw, only .4 amps. The fuse for the bathroom fan is 7.5 amps.
I checked on the manufacturer's website for impedance protection and I didn't find any info about them being protected.
My last idea to hook up direct to the battery (fused) to see if it's something about the wiring they don't like.
My trailer is a 2019 Gulfstream innsbruck 199RK. The lights are LED, but the bathroom fan is labeled as 12 volts. Is it possible when plugged into shore power that it runs off AC?
I haven't found my multimeter yet, but it's in here somewhere. I don't see how I don't have power at these fans when hooked up to a power source that is 12 volts and they won't work.
Does anyone have any ideas?
  • Your fans would exhaust more air if they were in a shroud which would not allow some portion of the air moved, to do a quick U turn and go through the fan again.
    I've emplyed a 160CFM 230MM 12v computer fan as a stick and brick bathroom fan that could not use the traditional bathroom fans. Mounted in a acrylic tight fitting shroud in an upper window exhausting. Close the door and place a round pencil in front of it the 1/2 gap under the door, and it rolls across the room from the air flow from the fan on the other side of the bathroom. Without a shroud, fan just leaned against the screen, the pencil stays put with little discernable airflow coming under the door.
    120Mm fans are numerous. I like the Silverstone fm181, 180Mm fan, as it comes with a potentiometer for speed control. At full speed it draws 0.28 amps and moves 160CFM and is still quiet. At lowest speed it is ~60CFM and practically silent, and 0.09 amps
    Noctua makes extremely well designed computer fans.
    The 200 MM NF A20 consumes 0.08 amps at 12vDC, and moves 86CFM for 18DB
    More airflow than your 2 fans for 1/5 the electrical comsumption and likely half the noise, or less.
    NOctua also has industrial fans, and some of these are IP 67( others are IP52) ratings, which should be better for cooking under. I have cooked under a silverstone fm121 for going on 8 years so apparently the grease and cooking fumes are not really a worry.
    Noctua has their own PWM speed controller that can control multiple fans' speed
    The 3000 rpm Industrial Noctua NF-f12 9120mm) draws only 0.3 amps and moves 110CFM and has a very high static pressure rating, and can easily be tamed to tolerable noise levels with their speed controller.
    I employ two of them as intake fans, along with the silverstone fm181. Al three of them on max speed draw less than an amp and if they had no airflow restrictions in front of or behind the impeller, would move nearly 385CFM.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
