gocamping14's avatar
gocamping14
12 volt electrical
had a 12v electrical drain in camper, seem to have found the issue, but in the process of elimination found another puzzling issue. have a WFCO elec. box. **the camper was not hooked up to shore power during the experiment below, only on the battery, fully charged** camper in barely 3 years old, with minimal miles.
have 8, 12v, 15amp fuses. I pulled all out in troubleshooting the previous problem. only 3 of the 8 red lights camp on indicating a blown fuse or break in the circuit. should have all 8 red light come on??
fuse #1 (lights) tested 11.43v again no fuse in
fuse #4 (furnace) tested .93v
fuse #5 (radio) tested 12.34v
fuse #7 (kitchen) tested .05v
the other 4 terminals tested 0 volts.
why was there volt present in some terminals and not all ?
any thoughts appreciated.............ss
  • The reading you get depends on the type of load the fused device is presenting. In your case, the radio's memory is a heavier load (relatively) than the furnace in it's standby mode so the voltage is higher. The loads of those devices are creating a connection to ground and completing the circuit for your meter.
    The path to ground provided by some of the smaller loads may not be big enough to provide a ground for the LED's to light.
    So what your seeing is reasonable.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 10, 2025
