3_tons
Dec 23, 2022Explorer III
First, You need to determine whether it’s a dc 12v compressor fridge OR a 12v heater element fridge…A compressor fridge is more efficient and typically has better insulation…
For solar, the method I use for real world ‘calc purposes’ (obviously region dependent) is to de-rate the panels by 50%, and to assume a 60% refer duty cycle - add to this your normal usage, and battery’s starting SOC (state of charge*), then plan for a day or two of minimal harvest..
* will require a Lithium capable battery meter like a Victron (smart shunt or BMV 12) or equivalent…
3 tons
3 tons
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
