If you still have the 1996 Lance, odds are the 12 volt element is DIRECT, without a Tstat. Back then, the 12 volt element was direct wired thru the selector switch. The 12 volt element on direct wired refers is ONLY for cooling when the Truck engine is on and you are in Transit. The 12 volt element keeps the existing cold in the refer and is not designed to cool the refer down. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
