mustangglp's avatar
mustangglp
12 Volt Inverter
The wife wants to watch tv while we're camping.
So I got everything I thought i would need?
12 volt inverter http://www.amazon.com/Cobra-400-Watt-12-Volt-120-Volt-Inverter/dp/B001RNOHBC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1373156849&sr=1-1&keywords=12+volt+inverters
12 volt lcd tv
VIP211k HD Receiver with hard drive that I took out of our bedroom
So here's the problem when I turn everything on the inverter gives a low battery warning?
My batteries are not low slightly over 13 volts with the solar charging the two new group 27 batteries.
What i think I need is a heavier cord to go from my 12 volt power outlet (it says 8 amps on the wall plate seems like more then enough ?) Do they make a 12 gauge power cord?
It works fine if I hook it up one of my old batteries direct with a heavier wire. I would like to be able to plug it into my power outlets so I can move it from the living room to the bedroom without having to hard wire the inverter.
Thanks Gary
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
