- Sandia_ManExplorer IIAbsolutely. We use a smaller 350 watt inverter mounted in our entertainment center to easily power our 32" HDTV, HD satellite, and DVD player. Obviously, the amount of time you will be able to utilize your inverter for this purpose will depend on how much accessible 12 volt power reserve you have onboard your rig. A means of recharging must also be considered as it is best to not discharge your battery bank below 50% which could severely shorten a battery's lifespan. We run our onboard generator an hour or two daily allowing our Iota IQ4 converter to quickly restore consumed amphours.
- PeePawExplorerThanks to all of you for your help. Special thanks to 2oldman for the link to 12v side of life tutorial. I printed it off and it will go into the library for study material. ;0)
Thanks again for everyones input. - pianotunaNomad IIIHi,
Likely a 300 watt pure sine wave invert will all that is needed for a tv. Be aware that a 300 watt inverter going "flat out" represents a load of 30 amps on the battery bank. - Yes. Then get some solar to keep the battery charged and you are golden.
No idea the % of MH with inverters. Easy to add if desired. - Yes, you can use it for TV. Get one a little larger then needed for the combination of a TV, DVD/VCR and satelite receivewr.
Not all MHs come with inverter. Some are optional. These are normally larger inverters then needed for light loads like entertainment equipment.
Remember you may need another battery! - old_guyExplorertakes a lot of battery though.
- 2oldmanExplorer IIyes, some do. Subject gets discussed a lot in this forum.
Don Rowe site Inverter FAQ
Inverters by Phred
inverter thread
MSW v. pure sine
Battery FAQ
This tutorial may be of some help. 12v side of life.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
