Have a 2012 Open Range 5er. My 12volt works on my landing gear and my slide outs but no 12 volt lights, water pump, awning and the fridge wont fire on propane (AC is fine on everything.) Brad
Many converter/inverters have small push button circuit breakers on the side of the unit. Check and make sure those are not tripped.
You may also have a "salesman" switch that turns off most of the 12vdc power. Mine is located just inside the entry door and is easily (and inadvertently) touched when entering or leaving the coach.
Ron
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
