wa8yxm
Feb 29, 2016Explorer III
The easiest way to reduce voltage is to pass the power through a high current diode.. You can get Diode Isolators at most Auto Parts places and RV stores, they are fairly large (Finned, and have 3 or 4 or more bolts (3 big minimum) you will use the center BIG bolt (IN) and one of the out bolts (or y0ou can parallel both of them, does not matter) each one will cause a slightl drop in voltage.
What I can not tell you, since it depends on the diode, is the voltage drop So measure.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
