wa8yxm
Mar 22, 2020Explorer III
If you want a weather cover you need only go to your regular hardware they ahve both SINGLE and DUAL (Duplex) outlets with weather covers.
If all you want is a single outlet someone published a snap in model up above. just cut the hole carefull
Or you can go to the aforementioned hardware for they have both single and duplex. both surface mount boxes and In-wall boxes.. Multiple designs
They also have 12 or 14 ga flexible wire to run that cord back to the inverter and plugs to plug into the inverter.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
