BFL13
Aug 09, 2018Explorer II
I am not asking this the right way, so I will try to be more technical. :)
The inverter is running just fine and the load is running just fine and the batteries are supplying the inverter just fine and all is well.
But can the appliance have some sort of twitchiness, that goes down its cord into the inverter's receptacle and tickles the inverter farther inside in its circuitry? Not to stop it from working, but just to bother it a little?
And if so, and you have two appliances doing that but in different ways or amounts, would that bother the inverter even more because the two tickles are not quite the same?
And do inverter's have some sort of filter against that tickling getting inside past their receptacles?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
