Sam_Spade
Aug 10, 2018Explorer
BFL13 wrote:
(the above about "no feedback" might be me using the wrong terms?)
It seems like you are concerned about "noises".
An inverter often makes noises that range from a low hum to a high "screech" depending on the design, and the noises vary DEPENDING ON THE LOAD. That is perfectly normal.
A generator's "note" changes with the load too.
While on commercial power, you should NOT hear any noises that vary with the load.....except maybe from an active power filter. If you do, there might be a connection going bad somewhere or a component getting weak (breaker).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
