3_tons
Aug 12, 2018Explorer III
I can see where a heavy inductive load like an air conditioner upon start up would cause a brief voltage sag along with a current inrush, but a programmable inverter should sense these conditions and correct the voltage accordingly assuming there was no cabling bottlenecks between the battery and inverter...
On the other hand, AGM’s respond a bit quicker that conventional wet cells...
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
