BFL13's avatar
BFL13
Explorer II
Apr 01, 2017
120v LED vs CFL vs 12v Lamps Results
Following up on another thread discussing using inverter and 120v lights with LEDs or CFLs. I have been using a CFL for a reading lamp for some years, but now have an LED bulb to make a comparison.
3000w Inverter on no light but various parasitic 12v things--1.7 amp draw seen on Trimetric monitor.
One double 12v lamp- 4.4 amps-- adds 2.7 amps
12v lamp no inverter--0.7a light off, 3.4a on--adds 2.7a
One 13w Sylvania CFL - 2.7 amps--adds 1 amp
One 5w IKEA LED- 2.2 amps-- adds 0.5 amp
(no comparable 12v LED to test here, sorry)
The three each have about the same light--no actual measurement of that.
So using the 120v LED with inverter is 2.2 amps as seen on Trimetric, while no inverter on, plus double 12v light is 3.4 amps for about the same lighting.
    Thank you for doing this!
    So if I understand correctly, using 120v inverter is 1.7 amps + .5 amp for 120V LED bulb?
    VERY interesting!
  • After making a few random measurements in the past, my conclusion is that LED lamps are a little more energy efficient than CFL lamps. About a 10% power reduction for the same amount of light (a subjective, no instrumentation measurement for the light level). LED lamps that flicker at 60 Hz can drive me nuts. I see this mainly in Christmas lights.
  • BL13
    It's no secret that fluorescent lighting strobe bothers old folks (me). I can try and trick myself but my eyes do not cooperate. I read a minimum of three hours in bed per night. Three hours under fluorescent lighting and my eyes ache. Using 5K LED lighting they don't.
    My recommendation is for seniors to try different lighting, including kelvin temperature and lumens. Whatever works, works.
    I wish I could lose say 50 years off my age but I'd settle for twenty (sigh).
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
