Rbertalotto's avatar
Rbertalotto
12V AGM -Size 31 - $179 ??? (Sam's Club)
This battery seems like an exceptional good deal. Am I missing something here?
Duracell® AGM Deep Cycle Marine and RV Battery - Group Size 31
Features:
Marine AGM batteries are specially designed for engine starting and the long deep discharges typical of marine applications. The maintenance-free AGM* design immobilizes the electrolyte making them spillproof and leakproof, so they’re safe to use no matter how much your tiny ship (or luxury yacht) gets tossed. They are available in all popular marine sizes with abundant cranking power for quick, easy starting and all the reserve power necessary to keep your auxiliary equipment running strong.
ONLY AVAILABLE IN AL, CT, DE, FL, GA, IL, IN, KY, MA, MD, ME, MI, MS, NC, NH, NJ, NY, OH, PA, RI, SC, TN, VA, AND WV
Specifications
1 amp hour rate:68.2
100 amp hour rate:110
20 amp hour rate:105
3 amp hour rate:85
5 amp hour rate:86
6 amp hour rate:87.4
8 amp hour rate:90
BCI Group Size:31
CCA at 0 degrees F:800
MCA at 32 degrees F:1000
Minutes at 15 amps:348
Minutes at 25 amps:210
Minutes at 5 amps:1265
Minutes at 50 amps:87.4
Minutes at 75 amps:53
Minutes at 8 amps:706
Reserve Capacity:200
Volts:12
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
