Almot
Mar 02, 2017Explorer III
westend wrote:
I'd suggest that before you start acquiring anything, you do some sort of energy audit to estimate the amount of power you'll be using. Without any educated estimate of power use, the implementation may be either over-kill or lacking.
x2. With only only two comments - go big on solar, no matter what. You can't have too much of it. Eventually the solar size will be limited by roof real estate and plan, and here comes comment #2:
GO AND SEE YOUR DREAM TRAILER IN FLESH.
Step inside, open cabinets, check - sit/lay/walk around - kitchen, bedroom, toilet as if you were using it. Your pre-conceived ideas - about sunroof vents etc - could change then, same as your ideas about solar. Dark kitchen, short bed, impossible washroom - who knows what else...
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
