dougrainer
Aug 20, 2018Nomad
time2roll wrote:dougrainer wrote:So you are just waiting for a problem to burn the thing out? No thanks, if there is a fault I want power off until the issue is resolved.
Now, if you have a Short, you do NOT install a Auto reset Breaker. ALL that will do is burn out the Auto Breaker. Doug
Have seen posts of these things fail in a closed position or burning up. Does not sit well with me as a safety device. Sure they work fine as long as there is no fault to protect.
There will always be a naysayer, no matter what the facts. I can't believe you have ever flown on a commercial airline with your negative outlook:B They have used Auto reset 12 volt breakers for YEARS on RV's. A LOT of Diesel Motorhomes have at least 30 Auto resets on there panels now. What type of breakers do you think they use on Airplanes??????? Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
