BobnSofi's avatar
BobnSofi
12v connectors, want 2 set up better system than Cig Lighter
Hi All,
We do lots of dry camping
as time goes on we have more and more 12v connection needs for laptops and phones, and the cigarette lighter connection is not so fun (rubber bands to hold them tight).
our laptops run at 20v, and we have cigarette lighter power supplies (12v => 20V), and we use them in different areas of the coach.
How do you all PROS get away from the cigarette lighter 12v connector for quick connect?
We could set up an inverter system, but it seems inefficient to from 12vdc to 110vac, and back to 20vc.
SO, THE Q IS
WHAT TYPE OF 12V QUICK CONNECT, QUICK CONNECT, QUICK CONNECT IS BETTER THAT A CIG LIGHTER QUICK CONNECT?
!!! thanks in advance !!!
  • This is what I used, with a 20A fuse:
    One in Bedroom to power CPAP, At least one at front of coach for computer, inverter, gps, whatever.
    It might be slightly 'inefficient', but it's a whole lot cleaner.
  • Go to a dealer for truck parts, and get "power Points" rather than "cigarette lighter plugs". They are made better and with larger wiring, especially designed to probide 12v power for whatever. Connect to an good source of power, either coach or chassis, whichever you desire. Use fused and good sized wire(12G) or better.
  • This is what we used on our boat.
    Multiple female sockets around the cabin, and male plugs as needed.
    Link: Connectors
    Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
