I bought a TV that has an external power supply. It says 19.6v on the little box. Is there anyway to go from 12v to 19.6v without going through an inverter? Thanks Linc
I suggest getting a TV that actually RUNS on 12 V for the RV.
But even that solution isn't perfect......as you need a 12 V outlet nearby AND I discovered mine won't run if the input voltage is above 14.2 or so. A minor inconvenience.
