I bought a TV that has an external power supply. It says 19.6v on the little box. Is there anyway to go from 12v to 19.6v without going through an inverter? Thanks Linc
If you will be using a DVD as well, you already are using an inverter, so might as well use that for the TV too.
BTW unplug the TV when not in use when the inverter is on for something else in the rig. The TV has a draw in standby when "off". A power bar with its own switch is good for that.
