Gargamel's avatar
Gargamel
12V electrical problems
Ok. So my 12V lights or any of the 12V system for that matter is not working in my MH. I have used a voltmeter on the batteries and I'm getting 12.6V. I have also measured the positive end of the fuses in the converter with the negative lead on the casing and am getting the same 12.6V So I know the power is making it to the distribution center.
When I plug in to shore power the 12V lights come on, but They will dim and brighten about ever 5 seconds or so consistently. Every time this happens I hear a toong! sound. I should have checked into the sound more closely in hindsight but I assume it to be a relay or solenoid inside the converter clicking over. This is very puzzling to me as this did not happen last summer when using the MH.
I also checked the 30A fuse on the wire going from the battery to the converter and got a resistance reading across it so I'm sure that's good. Also I checked the negative cable ground to frame and that was nice and tight. I have cleaned the corrosion off of all of the battery cables and I'm POSITIVE (pun intended) that all of the connections are good.
There is a thing along the negative battery cable between the battery and frame ground that appears to be a resettable breaker (at least it looks a lot like one). The only thing about it though is that it has no reset button on it anywhere. Believe me I checked all around on it a few times for a button and there is nothing. When I measure from the positive battery connection to the connection on the negative side AFTER or BEHIND this resettable breaker? thingy I am only getting about 2ish to 4ish volts. Is this my culprit?
Any help would be appreciated. I have reservations for a week long period in about 2 weeks and would really like to have the lights working. Thanks in advance for any suggestions!
Greg H
  • Also, could the thing with the converter dimming then brightening the lights and clicking have something to do with the battery system not being properly grounded? I had read somewhere that the converter will click over (with the relay) to use a second converter to charge the battery. Or does the battery help to supplement the converter when connected to shore power?
    When I first measured the battery 2 days ago it was only 9V. The next day it was 12.6V. There is a solar panel on the roof which charges the battery, so I believe this is why it went up to 12.6V in a day. Could this have something to do with it?
    Sorry for the long-winded posts. I just really need to get to the bottom of this issue soon.
  • It's always the ground wire. You have a ground wire that is causing you some problems. That's my guess at any rate
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 14, 2025
