Gargamel's avatar
Gargamel
12V electrical problems
Ok. So my 12V lights or any of the 12V system for that matter is not working in my MH. I have used a voltmeter on the batteries and I'm getting 12.6V. I have also measured the positive end of the fuses in the converter with the negative lead on the casing and am getting the same 12.6V So I know the power is making it to the distribution center.
When I plug in to shore power the 12V lights come on, but They will dim and brighten about ever 5 seconds or so consistently. Every time this happens I hear a toong! sound. I should have checked into the sound more closely in hindsight but I assume it to be a relay or solenoid inside the converter clicking over. This is very puzzling to me as this did not happen last summer when using the MH.
I also checked the 30A fuse on the wire going from the battery to the converter and got a resistance reading across it so I'm sure that's good. Also I checked the negative cable ground to frame and that was nice and tight. I have cleaned the corrosion off of all of the battery cables and I'm POSITIVE (pun intended) that all of the connections are good.
There is a thing along the negative battery cable between the battery and frame ground that appears to be a resettable breaker (at least it looks a lot like one). The only thing about it though is that it has no reset button on it anywhere. Believe me I checked all around on it a few times for a button and there is nothing. When I measure from the positive battery connection to the connection on the negative side AFTER or BEHIND this resettable breaker? thingy I am only getting about 2ish to 4ish volts. Is this my culprit?
Any help would be appreciated. I have reservations for a week long period in about 2 weeks and would really like to have the lights working. Thanks in advance for any suggestions!
Greg H
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
