agesilaus
Mar 26, 2020Explorer III
DarkSkySeeker wrote:agesilaus wrote:
Even small 120 VAC heaters are 1200 to 1500 watts...
Thanks. Yeah, I was imagining a big resistor with a heat sink around it that would run passively. Perhaps I will find that.
That's what these electric heaters are. Resistor: NiChrome wire coil
Heat Sink: The surrounding air
The problem is that it takes many Joules to heat up that air and get ahead of heat losses thru the walls, air leaks and such. You can't sneak around the Laws of Thermodynamics.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
