DarkSkySeeker
Mar 26, 2020Explorer
DrewE wrote:
A big resistor that can dissipate a lot of power at 12V, sufficient to be a useful heater, is also a low-valued resistor, on the order of one ohm (approximately 150 watts). Making your own with resistance wire would probably be easier and less expensive than finding and affording a commercially produced resistor, marketed as such. Having a few coils wired in parallel is probably a good idea, too.
I'd think, for heating with solar power, that a solar water heater (as in a black pipe in a reflective trough or something similar) and a radiator of some sort would be more efficient and effective overall. The cost would probably be lower, too.
Agreed. My basic motivations are like this: I have these solar panels and what if I used them to generate ~500W continuously? And to avoid the complexity of a water heater based system, I wanted to be able to attach the 1 ohm resister(s) to create passive and unregulated heat.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
