DrewE
Mar 26, 2020Explorer III
DarkSkySeeker wrote:
What if I bought 5 of these, wired them in parallel, and mounted them on a board?
PRODUCT LINK
At 12V, Ohm's law says that 1.2A would flow through each one, which means a dissipation of a bit under 15W each. Total wattage would be around 150W. To get 50W power dissipation, the applied voltage would have to be a bit over 22V.
According to the resistor data sheet, with no heat sink (i.e. mounted on a board), rated dissipation is 14W. To dissipate 50W each you must have a heat sink to keep their temperature reasonable. In either case they ought to be mounted on something that can take the heat; a wooden board would not be the wisest choice in my estimation.
$35 seems like a lot of money to spend for the anemic results you'd tend to get.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
