pianotuna
Dec 16, 2014Nomad III
Hi,
Rule of thumb is divide input watts by 10. An 1100 watt micro might have an input of 1500 watts, so demand may be on the order of 150 amps. Unfortunately there is another factor called a Peukert Calculation so apparent draw may be a heck of a lot larger.
On a 170 amp-hour battery bank a 150 amp draw jumps up to 354 amps after the calculation. Your batteries will unlove you at that level of discharge.
Basically you can probably get away with heating up a cup of coffee, but a 15 minute run time may take the battery bank down below 50% state of charge. It may be possible the batteries would be permanently damaged.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
