pianotuna
Dec 16, 2014Nomad III
Hi,
The alternator will indeed help--but not more than about 30 amps of the load when the engine is at idle. Total load is in the 150 amp range.
Choices are a large upgrade to the battery bank capacity (with medium to large solar), or burn some propane.
All my cooking is done electrically. My "instrument of choice" is a NuWave induction cooker. They require pure sine wave. I do use the microwave for heating left overs and beverages, but it draws 1591 watts, so I avoid long run times.
DAS26miles wrote:
What would happen if I used the inverter and started up the MH engine? Would the alternators charging offset the draw from the inverter?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
