BFL13
Dec 18, 2014Explorer II
jrnymn7 wrote:
Piano,
I have the Xantrex PROwatt SW 1000.
Sorry, I can't say with any certainty, as to the 120v draw. I've been meaning to confirm with my kill-a-watt, but according to the display on the Xantrex, the 700w Danby pulls over 1200 watts. BFL has the same microwave, and he said that seems too high? Ours are both rated at 1080w, I think it is? What's worse, the Xantrex doesn't even register anything under 18w, so that could push the wattage up even higher.
As for 120 line voltage (drop), that too needs to be confirmed with my kill-a-watt. And if I remember correctly, the Trimetric's display says the microwave pulls in excess of 90a?
Vbatt drops to the low 11's, on say a 90% bank.
But I knew going in, I was taxing my system by using the microwave. At some point, it just makes more sense to run off gen power. For example, 5 minutes of microwave time can easily turn into 20-30 minutes of gen run time, to replenish the Ah's used. Same goes with any high power-hungry appliance. But running the gennie for 5 minutes is quite ridiculous, as well, so...
To clarify, my inverter is a Can Tire 1000w PSW made by Xantrex. It has a continuous rating of 1000w and it will run on overload for 5 minutes.
When I ran my Danby 700 the inverter red light was on for overload. The watts readout was 1050w approx. (from memory) I did not have the MW running more than 5 minutes for that test. Trimetric amps was close to 100 (high 90s ISTR) Inverter connection to batteries is two 16" (approx from memory )lengths of store-bought #4 starter cable.
Manual says after the 5 min of overload you have to wait 15 minutes before it will do that again.
The manual does say the wattage it can do varies with temperature but not by how much. Rating is for 77F.
