Some of the TVs that use a brick are 14 volt. These will work just as well as the 12v. The voltage is usually marked on the brick. Don't ask the salesmen about 12v TVs, they don't know.
The advantage of using a 12-14 volt TV is it uses less power than using an inverter. Not important if you have hookups but if you are camping off the grid it will reduce the current drain and allow you to watch TV longer. It also allows you to hook-up the TV once and use it whether or not you have hookups without re-hooking up the TV.
Yes, I have a 12v TV.
