RoyB
Dec 14, 2015Explorer III
The real beauty is with two each 6VDC golf cart deep cycle batteries in series weighing 61 lbs each will give you 12VDC at around 220AHs for around $160... A single Trojan T1275 12V deep cycle battery weighing around 82 lbs each will give you 12VDC at around 150AHs and will cost around $250 dollars. Two mounted in Parallel will give you around 300AHs for around $500...
If you are on a budget then the cheaper golf cart batteries are the way to go...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
