AZDesertRat wrote:
I know they are not true deep cycle and I have no intention of going to 6 volt batteries.
Which would be your choice between the Interstate SRM-29 and the WalMart Everstart Maxx 29DC? I can get the Interstates for $119 and the Everstarts for $99. They both weigh 61 lbs. I found the specs on the Interstate and its 1 year warranty but can't find anything on the Everstarts?
I am buying two to go along with my two 100w solar panels and Phocos controller for short boondocking trips in AZ with plenty of sunshine.
I'm with you 100% on staying with 12V RV batteries - mostly due to the standard automotive sizes they come in. The convenient battery storage area that Winnebago built into our Itasca Class C motorhome is right under the entry step and is accessible from either outside the coach or inside the coach. There's room there for two 12V batteries up to Group 31 in length and width, but the area is not tall enough for 6V "golf cart" type batteries.
That being said, I will not use "marine/deep cycle" 12V batteries in our RV. Only true deep cycle batteries will do ... and you usually can't find them at Walmart, Costco, Sears, Napa, O'Reilly, etc. type stores. Of course these kind of stores do carry true deep cycle batteries -> the taller 6V "golf cart" batteries. That's the reason so many RV'ers use 6V batteries if they can fit them ... they're readily available and not too expensive.
However, there are true deep cycle 12V batteries available in the standard automotive sizes. They're available in regular flooded (liquid) acid types and in dry (AGM) acid types, but both technologies will be more money than non-true-deep-cycle 12V marine/deep cycle flooded batteries and true-deep-cycle 6V golf cart flooded acid batteries.
Here's a link to a quality true deep cycle flooded 12V battery in Group 27 automotive size:
http://www.trojanbattery.com/pdf/datasheets/27TMH_Trojan_Data_Sheets.pdf(I use a couple of true deep cycle Group 31 AGM batteries in our RV - for a total of 230 amp hours.)
