full_mosey
May 08, 2015Explorer
jrnymn7 wrote:
full_mosey,
Which controllers did you compare?
thanxx!
Morningstar.
It was not a back and forth comparison as the PWM was being replaced.
The 9A+ figure was the best I could recall over about two years with the PWM. The 10A+ figure was observed within a few days after installing the MPPT. I do not monitor Amps unless setting up a special driveway test.
BFL13;
The driveway tests are with flat panels attached to the roof rack of my van. The driveway tilts north giving a negative tilt which is expected to yield less than ideal readings when compared to the panel specs. The Isc of one panel is 5.12A and the Vmp is 18.3V.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
