jrnymn7
May 08, 2015Explorer
BFL13 wrote:jrnymn7 wrote:
Even with 12v to 12v mppt being more efficient, wouldn't 24v to 12v mppt yield more in the way of Amps to the battery? And would it depend on whether the 24v is from an actual 24v panel, or two 12's in series?
My answer to that first question is right there in the OP assuming 24-24 is like 12-12
The second question would depend on any wiring losses from the parallel links which you don't have with a single panel? I don't know any reason why they should be different otherwise. (Except in partial shade maybe)
What I find most interesting is that higher Isc proportion in the single 230w than in the 130w, which ought to make the single 230w with PWM (so it would have to be on a 24v battery) do more amps than two 115w panels in series with PWM on a 24v battery.
Ah yes, that's what you made reference to, earlier. So let's compare:
24v / 250w panel, Isc 8.39a
12v / 125w panel, Isc 7.38a (7.97 x .9259)
8.39/7.38 = ~ 13.5% extra!
