BFL13
May 10, 2015Explorer II
I don't know inverter brands, but don't forget it is not the size of the inverter in watts that matters for how much of a battery bank it needs.
It is the size of the load on the inverter that counts. You can run lots if stuff with a two battery bank with a big inverter as long as the loads are not too big left on for too long.
BTW, can you arrange your 24v( two 12s?) and 12v house batteries as a bank of three 12s? That size 12v bank would let you run a bigger 12v inverter from which you could run your 24v charger to charge those things?
I don't follow what who is doing what to whom in the 24v charging side.
